tbi to carb
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Axle/Gears: Borg warner 3.08's
tbi to carb
Im buying a tbi 350 out of a 93 chevy van. I was wondering if my mechanical fuel pump will bolt up on the newer motor? What would i have to do to hook up the tbi in my car? Thanks for the help.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: tbi to carb
Fuel pump issue is tricky, especially with the later TBI 350s. Some blocks have the provisions machined and covered with a block off plate. Some blacks have provisions that were never machined. Some lack provisions all togather. To further complicate the issue, you could get two camshafts in TBI 350s. You could have a light duty engine with a hydraulic flat tappet cam that still had a fuel pump lobe or you could get a heavy duty engine running the peanut 305 roller cam that lacked a fuel pump lobe. The only way you could bolt a fuel pump and pushrod into the block and have it work is if you had a light duty engine, machined for the fuel pump and covered with a block off plate.
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: tbi to carb
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: tbi to carb
Well im going to have the engine on a stand. If there is a hole can i shine a light in the hole and hand crank the engine and look to see if it has the right cam? If so what do i look for?
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: tbi to carb
Well i took the plate off and there is a hole for the mechanical pump. How can i tell what cam i have can i look in the hole and hand turn the engine to tell.
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: tbi to carb
How can i tell what cam i have can i look in the hole and hand turn the engine to tell. Does anybody know?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Stick a fuel pump push rod in there all the way to the cam. Turn the engine over while holding the push rod against the cam (if the engine is on an engine stand, just rotate it so the push rod hole is facing up). Go through 2 complete crankshaft rotations - did the push rod move? Yes - it has a fuel pump lobe. No - it doesn't have a fuel pump lobe.
Car: 1985 Trans Am
Engine: built 355
Transmission: th350
Re: tbi to carb
Billy Decker
09-04-2015 03:46 PM
