1992 Firebird Schematics & Fuse Question
Car: 89 Firebird Formula
I purchased a 1992 Firebird V-6 3.1 & it will not start but if you put fuel in the throttle body she fires right up I was told there is a fuse well I tested and pulled all fuses they are all good and there is no specific fuse in panel for fuel pump ( Is there one on this car ) .Also I have located the relay is there a way to test that or just replace it? There is no power on the three point plug at the fuel tank (connector for fuel pump). If someone has the wiring Schematics I would greatly appreciate it and to tell me if there is a fuse somewhere would be great.
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 1992 Firebird Schematics & Fuse Question
When you turn the key on (but don't start it) do you hear the fuel pump run for a second or two? Is the security light flashing?
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
The fuse should be under the hood. If I remember right it is by the battery.
I do here pump for spilt sec and as for security light have to double check on that also .I have located the live 20 amp fuse to fuel pump it is on the passenger side by the windshield washer fluid bucket they say there are 2 fusses is this true?
