Need Timing Tab for 305
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
I have a 1990 L03 engine in my Formula. Some jack *** put on a Mr. Gasket chrome timing cover without putting a timing tab on it.
So I saw a tab in the parts store that bolts on, it's for a 7 inch balancer. But it's kinda short and looks like if I put it on it will sit at 2 o'clock. I have seen an original cover and it shows the tab at 12 o'clock. So, where do I get one that will sit in the right position? I have looked everywhere I know and can only find ones like the one I have.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need Timing Tab for 305
AFAIK there aren't any bolt-on tabs for the 12:00 position... use a tab for the 2:30 position and use a piston stop to remark your balancer.
Car: 87 Formula
I know this is old but I forgot I posted this thread a while back. Anyway there is a tab I found for sbc engines that sits at 12:00. I put it on but it just doesn't seem to feel right at all once I timed it. So I'm back to trying to figure out if the L03 is supposed to have a tab at 12 or 2. I have both tabs already.
The_Phoenix
02-04-2016 08:10 AM
