60 degrees of timing?
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
last week i replaced my distributor with a msd pro billet, when i had it out i set number 1 to tdc and the mark on the balencer was at 0, now to get my car to run with out a backfire off idle the base has to be at about 30 degrees and full timing at about 60, i was thinking the ballencer spun but if it did it shouldnt have been at 0 when i set the timing, any ideas what else this could be
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: 60 degrees of timing?
Really, so if I need to clock the distributor to clear something when setting the 36 degrees with the advance locked I can just clock the housing as long as the rotor stays in the same place?
That will help me out, thanks....
Engine: 383 Carb
Transmission: 4L60
You can install the distributor in any position at all, as long as when the engine is in #1 firing position the rotor is pointing to whatever terminal you have the #1 wire on.
Car: 89 formula
Engine: 305tpi
Transmission: t-56
the timing was the same with the old distributor but it would not hold time and it ran really bad so i just figured the problem was in the distributor, it was one of those msd knock offs from ebay
theshackle
09-17-2020 08:26 AM
