need some help`
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
need some help`
well i just bought a 750 dp quickfuel ss from a member off the board...
after numerous moving of vaccum lines and helicoiling two studs in the intake mani i got it on and running, car ran real good, then the fuel line started leaking, tried fixing it today and things got bad.
yesterday the car started right up and ran real good, today it seem to run really rough, seemed like a miss, while driving i couldnt get the car over 3 grand and the whole time it sputtered and acted like it was trying to die jut around the block.
i dont hear it sucking air, and the idle doesnt hang so i dont thing its vaccum...
so my two thoughts are a fouled plug or the carb is loading up, niether of which i have dealt with so how can i spot them?
and if anybody has any other possibibilties let me know.
also i have a holley red electric pump and i had it pumping fuel for 10-15 seconds while i was checking for leaks, and i had started it after a hour or so sitting, it ran better but still real rough around 2500 rpms
thanks for any help in advance
Car: 1987 Firebird
Engine: 355
Re: need some help`
have you adjusted the carb at all? Did you ask what jets are in it?
When i got mine, it seemed like someone had converted the jets to square jetting, but also left the powervalve circuit in there. The fuel bowls were set WAY too high, and i couldnt get it to run much. A few adjustments corrected that though, and it runs great noiw.
However, if youre having probs, ONLY above 2000rpm, you might have a timing issue.
Also, check your choke, and make sure its staying open. My choke has closed on me a couple of times at the track when vacuum was too high. It'll behave exactly like youre describing if that happens.
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Re: need some help`
Another thing came to mind also.
What do you have your fuel pressure set to?
I had a similar problem and found out my bypass regulator was not sending the correct pressure to the carb.
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: need some help`
First I would check the float level and jets size. Pull the plugs and see what they look like. Sounds like the carb needs tuning.
Car: 1987 Camaro
Re: need some help`
the carb is stock jetting and everything, it ran really good, then just decided not too run well, how would i go about making sure the choke is fully open
the fuel pressure is a constant 7psi with the holley pump i think...
Car: 1987 Firebird
Engine: 355
Re: need some help`
If you have a manual choke, just ziptie the mechanism fully open. You have to be fairly high in the revs, and let off all of a sudden, to create enough vacuum for it to close.
If its electrical, just unplug it, or wait long enough for it to open.
But you may have a fuel issue if it behaves like that above 3000.
Another though, check your fuel filter, maybe its clogged?
Car: 1987 Camaro
Re: need some help`
ya i didnt even think of the fuel filter, took it out today and its great under wot, but under light throttle it feels like it eases up a bit
the carb is electric choke and its unplugged...
Car: 1987 Camaro
Re: need some help`
today its running as bad as ever, started right up first time ran decent for about 20 secs then got real bad, changed out the fuel filter and it did nothing...
i did notice looking at it that the front left fuel bowl is only a 1/4 of the way full but the other three are completely full....would this be a sign of a problem?
