383 heads???
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
383 heads???
ok im putting together a 383 with flat top pistons that with a 64 cc chamber should give me around a 10:1 compression ratio
i want to spin it around 6000 and im looking at putting a nice set of aluminum heads on it
question is what should i use for heads im not really sure wat to use such as if im goin to need the bigger valves or what sized runners are goin to work best
all inputs are welcome
thnx
zig
thnx
zig
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 383 heads???
What camshaft are you using? What kind of intake setup? Engine's intended purpose? Those play a major part in deciding what heads are best.
That said - usually heads in the 195cc-210cc range are a very safe bet for a bigger SBC like a 383 or 406, though being on the small side of that is usually better for a primarily street engine. AFR makes a very nice set, as does Trickflow, and Brodix. World and Dart both make a 200cc head as well thats fairly inexpensive by comparison, but they are cast iron (which isn't really a bad thing, I have some 200cc Worlds that I really like).
Valve size doesn't make a big difference with heads like these, as they are already as big as can reasonably fit. 2.02/1.60 is the standard Hi-Perf valve set, so I wouldn't bother with anything bigger if it costs more (some mfg's have optional larger valve sets for some heads, like 2.05/1.60 or 2.08/1.60), they won't improve flow enough to make it worth it.
Engine: 383
Re: 383 heads???
well i was tinkin of using a vortec but since the bottom end isnt costin me as much i thought i would spend the extra on a set of aluminum heads
its gunna be a street strip car
i dont rember the exact spec for the cam but its a comp thumper cam rpm range 2000 through 5800 which is right where i want to be spinning it
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Forget the Thumper series. Made for noise, not power. The Comp Xtreme Energy series is a much better choice.
Take a look at the Fast Burn heads. Vortec pattern, 200cc intake ports, great out of the box.
Engine: 383
Re: 383 heads???
i chose the cam cause i wanted the thumpty thump at idle
my thing is its gunna be more of a street car than a strip car its just gunna be a nasty street car
so it has to be able to have the decent driving conditions i want it for
plus im using a 700r4 so out on the high way im only spinnin around 2000 at 55
Re: 383 heads???
Use the AFR 195cc, Trickflow 195cc, Dart 200cc Iron Eagles, or World Sportsman 200cc. Listed from best to last, but none of them will disappoint.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Engine: 383
Re: 383 heads???
i found some procomps on summit they had 190 intake runners
last time i looked AFR were out of the price range im still tryin to keep the heads around 1000-1200 at max
Re: 383 heads???
Check out the Brodix IK200s... very reasonable price, very good performance. Dart Iron Eagles are awesome too, and relatively cheap.
Engine: 383
Re: 383 heads???
alright i do have another question something i forgot about
being as its goin into a 91 fbody im goin to need heads with straight plugs to fit under the headers correct
zig
zig
Re: 383 heads???
Yes. Some headers work better with angled plugs than others. Safest bet is just to get heads with straight plugs though - if they are available with angled plugs, its usually optional - you can have them machined for either straight or angled when you order them.
Re: 383 heads???
Just go with straight plugs - theres no significant enough gain from angled plugs to justify the PITA they can be. The gains from angled plugs isn't much, probably not even noticeable.
Re: 383 heads???
Mickeyruder
09-02-2015 02:45 PM
gixxer92
09-01-2015 04:32 PM
