alternator wiring issues...
1 Post
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
in the pic, the orange wire (orange line and text inserted with it) comes somewhere from the harness and attaches there. the car's wiring has been butchered in a bad way by the previous idiots...
the black wire runs about two inches from that point to the positive terminal on the alt (IIRC it was a different color, but it was in bad shape and i had a little bit of black wire left over and replaced it). why would the wire run from the spade terminal right to the alt positive post?
it doesnt make sense and it doesnt follow any wiring diagrams that i have come accross.
the reason why i bring this up is that there is a relatively bad parasitic battery drain with the battery terminals hooked up.
any ideas???
background. was 305 TPI swapped to carbed 350 SBC, and the alt [which i replaced a while back and bench tested fine] is 305 specific NOT for the 350, even though they have the same connections it has a higher amperage. the alt is a stock advance auto remanufactured unit.
1 Post
Re: alternator wiring issues...
24 hour bump because i need to get her on the road. i am having issues with my daily driver.
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The short jumper wire is the voltage sense wire. Imho it should/could be run all the way to the battery in order for it to do something useful.
The orange wire should come from an ignition source (hot in run). If it's always hot it will drain the battery. Test with a test lamp, and try to disconnect wires at the alt to see if that's where the draw is.
1 Post
what is an example of a "hot in run" wire i could run her to? i will definitely test with some form of lamp.
1 Post
the wire is only hot when the keys are in at the accessory position. and had no power without the keys. so thats not the wire.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If you unplug both wires, does the voltage drain go away?
They may be reversed. That is an old 70's-80's delco S1 alternator. It needs a bulb or resistor in the exciter circuit to work (can't just wire it to ign+).
And 'wagon is right, the feedback wire needs to be at the starter or battery to do it's "job". Connecting it to the Alt+ is "rigging it".
1 Post
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
You can buy a new plug at most parts stores in the help section. Like stated above one wire hot all the time and one hot with the switch on.
Yes, get a new plug, or at least insulate those bare connectors. If the sense wire touches ground it will burn (or fry a fusible link).
Actually, the sense wire is usually "jury rigged" from the factory - so you can leave it like that for the time being but think of it as an upgrade.
The original exiter wire is brown, and should not be hot in acc.. You'll find wiring diagrams for your Camaro here: http://www.geocities.com/vtcamaro/Wire-Diagrams.html
eightsixseven
08-14-2015 03:09 PM
db057
08-11-2015 10:11 PM
