Need help 1992 Camaro RS 305 V8 serpentine belt question
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Hi everyone,
Just picked up my 1992 Camaro RS 25th anniversayr today I was quite excited. On the way home I threw a serpentine belt, no big deal. Well when I went to put one on I noticed that the unit with a pulley that is driectly underneath the air conditioning on the passengers side is GONE. Somehow the previous owner had that removed and ran a belt bypassing that pully all together. I worked on it all night and could not run a belt (tried all different sizes and ways to run it) without that pulley. I know there is a way since the previous owner did and the car was fine, any ideas or diagrams that may help me out. Has anyone else done this to their Camaro? Any help will be appriecitated since I want to get out driving my new toy ASAP!
Thanks,
Darren
Thanks,
Darren
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need help 1992 Camaro RS 305 V8 serpentine belt question
Welcome to TGO. A search will often find all the info you require. Try the following threads. The first has a diagram toward the end, the second info about the delete pulley:
http://sethirdgen.org/serpentine.htm
https://www.thirdgen.org/forums/faq-...lete-smog.html
JamesC
JamesC
Car: 1992 Camaro RS
Engine: 350 Carb'd
Thanks for the welcome and the quick help with my problem. I have tried to run a belt as that diagram shows without the smog pulley. But I have yet found a good fitting belt. I've tried a handfull of different sizes but do you have any idea if there is a certain belt or size that I can get to make it fit well enough to run. Any and all help is greatly needed and apriciated.
Thanks,
Darre.
Thanks,
Darre.
JamesC
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
You can also try Goodyear #4060967 either will work or just find a belt that is 97 inches long.
Car: 1992 Camaro RS
Engine: 350 Carb'd
Hey thanks guys I purchased that goodyear belt and ran it with the diagram using bypassing the smog pulley. Would you guys recomend leaving the belt ran that way or should I purchase the somg delete pulley to run the belt back the stock way?
Thanks,
Darren
Thanks,
Darren
Pretty much your choice. Personally (because I'm **** about such matters), I'd run the delete pulley.
JamesC
JamesC
Car: 1992 Firebird
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I've ran mine without the delete pulley for 2 years and she's doing great. It's a personal choice either way will do just fine!
Car: 1992 Camaro RS
Engine: 350 Carb'd
Hey thanks, I think I'll leave the way it is now. Try it out see what happens.
Thanks for all the help!
Pac J
05-17-2020 10:44 AM
