window motor help
Car: 92 camaro RS
Engine: v8 305
window motor help
i had another 92 camaro and saved the door for the window and bottons and window motor ect. my new camaros window motor has gone out so i took off the arm rest removed the door pannel and unscrewed/drilled out the rivetes when i unscrwed the motor and went to remove it when the motor moved away from the crank wheel it dropped the window really fast and i vagly remember one of my buddies telling me i needed to clamp somthing down to make sure the window doesnt fall inside and break i was just wundering what i should clamp or if i should just wedge somthing into the wheel to hold it into place so it doesnt drop the window
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: window motor help
You can do it many ways. You could clamp a small set of vise grips to the window track under the window. What ever you do make sure the window is secure so you don't loose a finger.
Car: 92 camaro RS
Engine: v8 305
it also says on most sites to tape the window into place how affective is thta? plus there is nothing to tape it to the top of the window
1992 Trans Am
05-10-2023 07:19 PM
