NEED VACCUM HELP FAST
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Ok, well i just got my ss 750 quick fuel that i bought from a guy today, I had a 600 holley, behind the carb i have a vaccum line port that is on the rpm air gap, i had it hooked to my brakes and another line that ran inside the car. Well the quickfuel is bigger then the holley and doesnt clear the "T" even with a 1'' spacer. Now what I am wondering is can I plug the pvc line, run my brake booster to the carb, and run both the distributor vaccum and the other small vaccum to the carb, the carb has three small things for vaccum.
lol i hope i didnt confuse anybody but what do you guys think?
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
Re: NEED VACCUM HELP FAST
The dist. vacuum needs to be on its own line. If you "T" it to something else, when that item uses vacuum it might change the signal and make the dist change timing when you havn't change rpm...If you "T" it to a vacuum gauge...then it shouldn't matter. The carb should have one larger tube, that one should be fine to use on brakes as long as it is below the throttle plates. (ie not a ported vacuum signal)
Car: 1987 Camaro
thanks, for the dizzy line i was going to "T" it i just wanted to plug it to one of the tubes on the carb, the carb has 3 small tubes and i wanted to use two of them for the dizzy and the other line...
