Signs of a bad neutral safety switch
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Signs of a bad neutral safety switch
- engine won't crank when clutch is fully pressed or auto shifter is in park or neural
- engine cranks without pressing the clutch or auto shifter in any gear other than P or N
Car: 1985 Trans Am
Axle/Gears: 9 Bolt posi disc 3:27's
If you have either of those 2 problems intermittenly then it is most likely the switch. If it is intermitten then ohm testing may not show a bad switch....but that is the test to use.
Street Lethal
04-30-2019 12:14 PM
diana227vegas
07-08-2016 12:27 AM
