Hooker 2460s and Plugs.
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Alright, Im having issues with my 2460s, melted the plug wires, so Im replacing the plugs and wires. I bought some Accel U Groove Shorty Plugs, and Accel 9000 Series wires. Got the drivers side done completely, and the front plug on the passenger side. But I cant get at any of the other ones on the passenger side, do I have to take the header off, or are there any tricks?
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
Re: Hooker 2460s and Plugs.
ive got ngk stand size plugs 750 reach. not a problem. i use a 5/8 wrench on some and for the hard ones that i dont want to risk rounding off i take a regular 5/8 in spark plug socket and cut off about 1/4 of the larger end. Then i drill out the ratchet side and use that with wrench to turn the outer part. (see slp special socket) you should be able to get to them all like this. I would look into some plug wire protective sleeves. They are kinda expensive but worth it in this situation.
PS see my thread in the exhuast forum and chime in. thanks!
https://www.thirdgen.org/forums/exha...-3rd-gens.html
Yea, I was thinking about doing that earlier. Im gonna try using something to hold the plug wires away from the headers, maybe next time Ill get a custom kit.
Car: 1982 Camaro Z28
Engine: 4bbl 305
Axle/Gears: 10 bolt posi
I just put in a set of Champion plugs and MSD Street Fire wires and for the last plug on the drivers side i had to lift the car and put it on underneath. Talk about no room. Maybe try that if you can, i got right to mine that way.
I took a spark plug socket cut off 1/4 inch and it worked fine, got everyone from the top. granted I used a wrench, and only had like 3/16 turns on some of em, those took a while. My hand paid the price to do em all from the top though.
no green
01-09-2016 09:22 PM
