can i use head #14101083 on a 305?
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
looking to replace 14102187 swirl heads with a set of heads from a 350 (cause I have a set laying around).Will the 1/4" difference in bore size cause a problem? Any help is appreciated very much...thanks
Car: 1983 G20 Chevy
Transmission: 4L60
Re: can i use head #14101083 on a 305?
You are better off with the 187s than the 083s with their larger chambers. That is unless you are going to supercharge it or hit it hard with nitrous.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
To answer your question the 083 heads will fit with no problems on your 305. Ever notice that the same head gaskets fit 305/350's?
Car: 90 formula
Engine: 305 carb
thanks guys...I was hoping with a thin head gasket I could overcome the larger chamber and get the compression back up with the larger chambers?
any thoughts
any thoughts
Car: 90 formula
Engine: 305 carb
yes,already have dual exhaust installed with no cats, changing cam and looking to dump the tbi for holley and use msd ignition box.
thanks
looking for more power and just having fun
thanks
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Out of curiosity, what makes you want to dump the tbi for a Holley with no feedback? Have you maxed out the tbi's flow capability?
Car: 90 formula
Engine: 305 carb
mostly because when I change something I dont want to constantly have to change the chip and I can also go to multiple spark discharge.
Car: 1983 G20 Chevy
Transmission: 4L60
You can go MSD without switching to Carb. I would actually go Crane Hi6 rather than MSD.
http://store.summitracing.com/partde...5&autoview=sku
The 083s have 65ish CC chambers vs. the 56cc chambers of your 187s. That will drop your compression more than 1 full point, even with .016" compressed rubber embossed 350 steel shim gaskets!
Car: 90 formula
Engine: 305 carb
thanks for all the info guys..im going to go with world 58cc heads rather than mess with the swirlies or 083,s
buzzman1
buzzman1
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 90 formula
Engine: 305 carb
are they easily attainable for under 1500.00?
are they easily attainable for under $1500.00?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 90 formula
Engine: 305 carb
do you know what the chamber size is cause im looking to stay under 60cc so I dont loose to much compression..where would I find newer take offs?
thanks
thanks
Car: 1983 G20 Chevy
Transmission: 4L60
Just an example of where they can be found. These are sold, but I see probably 1 pair a month on the classifieds here.
https://www.thirdgen.org/forums/engi...-aluminum.html
You can still get them brand new but you might as well go aftermarket if you decide to go that way.
The alternative would be the 56cc Trickflows with 175cc intake ports. (1.94/1.50 valves, but 245/180 cfm of flow @ .450 in a 3.776" bore)
The trickflows will run you about $1,000+ shipping, brand new, with warranty.
This build attest to the power of Trickflows, even on a high mileage less than perfect long block. The Edelbrock TES headers and remaining portion of the exhaust system are less than ideal. The little low-rise performer EGR intake was chosen for smog testing and the CCC Q-Jet system was left stock. This engine had ALOT of un-trapped power waiting to be released.
http://chevyhighperformance.automoti...ons/index.html
ambainb
04-25-2016 09:21 PM
