Any thoughts on this cam for this application?
While I know there are far better selection for forced induction engines. What are your thoughts on this cam for my application. Compression is 9.5:1 with aluminum heads and I plan on running 4-6 psi. As for forced induction, I may go with a single T-61 unit or a 144 Roots type blower. While I'd love to work on a 350 or bigger. 305 will have to work for now. It'll have a tremec T-5 and 3.42 gears. If I stay fuel injection It'll have TPI.
Duration @ .050" lift: 211/219 (int/exh)
Valve lift: .499"/.525" (int/exh)
CarGuyDennis
137
12-06-2016 11:02 PM
Mickeyruder
09-02-2015 02:45 PM
