Roller Cam Thust Plate Retaining Bolt Torque ?
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
Presently working on a Cam upgrade.
I looked at both the factory service manual and the threads and could not find any information about the specified bolt torque for the following:
Roller Cam Thrust Plate ( Cam Retainer) Bolt (Torx) Torque.
1987 Block.
Any ideas?
Best Regards,
Bruce
1987 Block.
Any ideas?
Best Regards,
Bruce
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Roller Cam Thust Plate Retaining Bolt Torque ?
you don't need to torque it just make it tight. what ever you do don't lose it though cuz no one will have it or know what your talking about
Car: 87 IROC
Engine: 420 EFI
Thanks for the response.
Shall I use a thread locker? Red or Blue?
Thrust plate Number : GM 10088128 : For TPI
Thrust Plate Bolt Number : GM 14093637
Best Regards,
Bruce
Best Regards,
Bruce
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you torque a fastener properly, it doesn't need thread locker.
Car: 87 IROC
Engine: 420 EFI
Thanks Guys,
Yes, this fastener is somewhat small.
Relative to the cam bolts, not much clamping force.
Too bad GM did not provide a torque specification.
Best Regards,
Bruce
Best Regards,
Bruce
Car: 87 IROC
Engine: 420 EFI
Hi Guys,
Just talked to LPE.
LPE looked-up the GM torque settings for this bolt.
Torque = 12 NM or 106 inch-pounds.
Install with red threadlocker.
Best Regards,
Bruce
Just talked to LPE.
Best Regards,
Bruce
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
84z96L31vortec
08-10-2015 08:27 PM
