help with firebird
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
help with firebird
my 88 firebird will start after a long time of cranking but as soon as it does it dies both my injectors are squirting and ive got pressure and ive got fire but it will not stay running all of my vacuum lines are good and all of my elec connections are hooked up. I scanned the ecm and no codes whats the deal any suggestions would be welcome
Engine: 2.8
Transmission: t5
Re: help with firebird
it runs maybe 4 2-3 seconds tops then takes about 10 cranks before iy will "start" again
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
First guess, flooded or lean. If it's flooded, holding the pedal to the floor while cranking should clear it.
If it's lean (low fuel pressure) spraying some carb cleaner into the intake to supplement what the injectors are providing should make it run.
Less likely but also possible, weak spark.
Car: 88 Firebird - SOLD!
Engine: 2.8L
I don't know enough about this circuit to explain, but I recall reading about the oil pressure switch providing a signal to the fuel pump relay. The circuit acts differently during cranking & if the switch doesn't see oil pressure after running it will drop out the fuel pump relay and shut engine down - checking fuel pump pressure during the start sequence may help you diagnose. Sorry for being so vague, but maybe someone can explain this circuit better.
Corky
Corky
Car: 87 Formula 350,11.65@122
Engine: 383,AFR Comp 195,XFI280,SRam/Mram
Transmission: T-56 Magnum-F
Axle/Gears: DANA 44 with 3.92
Could be a bad MAP sensor, they won't always throw a code. Be sure to check the vacuum line to the MAP sensor to make sure the sensor has not come apart inside and plugged the hose.
Engine: 2.8
Transmission: t5
now it wont even start but i did notice last night that the injectors are squirting but its just a small stream like a squirt gun from the dollar store,any thoughts. I appreciate all the responses ive got so far
Engine: 350 SBC TPI
Sounds like low fuel pressure. plugged filter and/or bad pump.
Dissconnect the fuel return hose and jump power to the fuel pump prime connector. Fuel should shoot out the return line (be prepared for it). If it does not and you hear the pump running, chances are good your pump is toast.
Engine: 2.8
Transmission: t5
where and how do i jump that to make the return line shoot
is that on the aldl connector ?
Last edited by mikey88firebird; 09-15-2008 at 03:04 PM. Reason: Automerged Doublepost
Engine: 350 SBC TPI
Fuel pump prime connector is a short red wire with a black connector hanging off of the Fuel Pump Relay. Conecting 12V battery power (being cautios not to cause sparks near the battery) causes the fuel pump to run.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Just disconnect the fuel return line and turn the key to "On". This should only be done with 2 people, anyway. No open sparks with an open fuel line.
Engine: 2.8
Transmission: t5
okay I know this sounds really noobish but i can not locate the fuel pump relay 88firebird formula 305 tbi 700r4 oh and i dont know if it matters but i noticed my fuel gauge is not working its stuck on full
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
