Engine HP rating confusion
Hey yall,
Im trying to get the HP/TQ specs for the 1992 Z28. I found this on here and Im confused about the HP/TQ rating for the LB9 V8. Looks like there are two different ratings...one for 205HP/285TQ...and another for 230HP/300TQ. Now, when I go to buy one how can I tell the difference and how do I know what LB9 the one I wanna buy has?
I looked at the VIN breakdown and it just says...F = 305 ci V8 LB9 (1987-1992). Dosent look like there is two seperate codes for two different LB9's. I dont think Im overlooking anything, maybe theres a unknown secret or something. Please help me out with this...I'd hate to buy a vert with 205HP when I could buy one with 230HP.
Thank you very much, I appreciate any help I can get with this one. Oh heres the chart breakdown with engine codes and HP/TQ ratings.
1992 Chevrolet Camaro Drivetrain List
YrModelTransEngine
code/typeCRDispl.HPTorqueInduc-
tionManual
std.Manual
opt.
(G92)Auto
std.Auto
opt.
(G92)92RSM5,A4LH0 V68.5:13.1 (191)140@4400180@3600MFI3.42----3.23----92RSM5,A4LO3 V89.3:15.0 (305)170@4000255@2400TBI3.08----2.73----92Z28M5,A4LB9 V89.3:15.0 (305)205@4200285@3200TPI3.08----2.73----92Z28M5LB9 V89.3:15.0 (305)230@4200300@3200TPI----3.42---- ----92Z28A4L98 V89.7:15.7 (350)245@4400345@3200TPI------------ 3.23
YrModelTransEngine
tionManual
std.Manual
opt.
(G92)Auto
std.Auto
opt.
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: Engine HP rating confusion
If it still has the sticker center console) look for the "N10" option. If it's not there, the easiest way would likely be to look at the catalytic converter(s) under the right side of the car. If there's two, it's the 230 hp (N10) car, if not it's the 205 hp.
Engine: LB9 225HP
Axle/Gears: 3:45BW
Sorry. I meant to write "Sticker in the Center Console."
It's just a listing of all the option codes. Look for the code "N10."
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Even easier is what kind of trans it has. auto get the weeker motor, manual gets the stronger motor.
The exhaust is not the only diff. The cam is diff too the auto got the smaller "peanut" cam in it.
Did they? I didn't think so but I could be wrong. I just wouldn't think that the dual cat setup would be worth a 15 horse gain on a 305. I wouldn't even think a full aftermarket exhaust would net that big of a gain.
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
The Automatic had 205hp, the manual had 230hp.
It says A4 for automatic 4gear, it says M5 for manual 5gear.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
