oil leakquest
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
oil leakquest
hey guys im back! im having oil leaking onto my starter and lil bit on oil pan. i replaced valve cover gasket twice, oil pan twice, intake, and resealed the oil sending unit to. is there a bolt or something that is by the starter? im getiing frustrated. thanks guys
1 Post
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: oil leakquest
since it seems that you covered the major areas, have you checked the oil filter and gasket. the reason i ask is that one time the gasket off of the old oil filter stuck to the block and i put the new filter on (with the new gasket) and it leaked. i took it off and saw the two gaskets, peeled the one that was on there previously off and no leak.
have you been torqueing everything to specs?
its a long shot, but may be worth checking out.
1 Post
Engine: 355
Re: oil leakquest
1 Post
Engine: 355
Re: oil leakquest
ok guys i looked and its only wet in the are of the starter. blocks dy, and every oil place with a gaket is dry. i pulled the inspection cover off and let it run fpr 30 mins. no drips... i dont kno what to do, im takin it for a spin now to see if it leaks.....
1 Post
Engine: 355
Re: oil leakquest
and wouldnt u kno it, it frealin leaks... its leaking all over the top and looks to be rolling to the bottom of the starter.. selinoid and wires are soaked to... possible dipstick issue?
1 Post
Engine: 355
Re: oil leakquest
oil is leaking around where the pan where dipstick goes into the pan. do i gotta pull pan again to get it to seal?
skinny z
10-05-2015 06:23 PM
