NEED HELP
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
NEED HELP
1988 350 TPI. When the car is on, and I go to rev it, it hesitates before it revs up. Like a miss fire, or no gas. When it gets to operating temp and reving it for a while it will stall. Also when I put it in gear, it goes to stall, or it does stall. This problem started out as a hesitation at cold start up and has progressed to this. I can't even drive the car. I have changed:
Temp sensor, fuel pump, fuel filter, fuel ingectors, tps, iac, distributor, coil, wires, spark plugs.
None of these things have changed the problem. Also no engine codes.
Car: 1988 TA GTA
Re: NEED HELP
I adjusted the tps, but I didn't know about the iac. How do I adjust that? Also when the the car hesitates when I rev it it sometimes has a little backfire in the intake.
