how much horsepower?
Car: 90 camaro rs
Engine: LO3 305 tbi
Axle/Gears: 3.42 posi
Ive got a 1990 camaro 305 tbi. I'm switching over to carb and a few other goodies. I'm wondering how much HP will my new combinations make? Here is the list.
Heads from a 91 gta that have been ported and have new comp springs
Edelbrock torker 2 intake manifold
Holly 600 4bbl carb
14in holly filter case with k&n filter
3.42 posi rear.
Holly 600 4bbl carb
3.42 posi rear.
Car: 85 IROC Z
Re: how much horsepower?
Will you be changing out the cam and why a Torker 2 intake? I would go with the performer or performer RPM air gap intake.
Car: 90 camaro rs
Engine: LO3 305 tbi
Not changing the cam just yet. When I do I will be going with the lt1 cam, I've heard good things about those. I went with the torker because I heard itd give better performance when mashing the gas. Would the performer have been better? This is all going on to my stock lo3 motor
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Holly 600 4bbl carb
3.42 posi rear.
Holly 600 4bbl carb
3.42 posi rear.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Torker II is terrible, you won't like it, especially on a 'small' motor like a 305.
With a 600cfm Holley, the best intake for you would be either a Weiand 8120 or Edelbrock Performer EPS. They are designed for use with tamer combinations like the one you have (fairly mild cam, smaller cubic inches) with a squarebore style carb like your Holley. They also will not have hood clearance issues, as they are only a little taller than your TBI intake was, but being modern designs, will produce a noticeable amount more power and torque.
dbrochard
09-25-2015 04:56 PM
