Can't make sense of block numbers
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
My 91 RS has a 350 in it with the original TBI. I have had tons of trouble finding time to work on it so I asked my mechanic to find the casting numbers for me while he was working on some other stuff. I know that sounds lazy that I couldn't find time to find the casting numbers, but the military keeps me really busy. He said he got the numbers off the rear of the block, but when I look the numbers up on mortec.com and other sites I can't make sense of them. Can somebody help me out?
Here are the numbers the mechanic gave me, in the order he wrote them down:
XU3E 6015 AB
Any help is appreciated. I'm trying to not only confirm that it is a 350, but hopefully find out what it came out of so I can get specs, roller or flat tappet, etc.
XU3E 6015 AB
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Can't make sense of block numbers
Casting numbers don't have letters. I have no idea what those numbers mean.
Your engine should have 5.7L or 5.0L cast into it also which makes it easier to tell if it's a 350 or a 305.
If the engine is original, the VIN code will tell you what it is.
Car: 1987 Z28 Camaro
Engine: 305 TPI 5.0
the number you need is on the right side of the block right behind the aldanater they are hard to read some times if you buy the haynes book for the camaro it tells you everything you need to know they run like 15$
Engine: 350 TBI
It is def not the original engine. I got a PM from a TGO member saying those numbers indicate a 69 pickup engine. Being that old would explain the lack of teh 5.0 or 5.7 stamping.
evilstuie
02-28-2016 03:33 PM
rithsleeper
08-11-2015 07:55 AM
