pushrod question
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
pushrod question
i am wondering what length of pushrod i need for my motor. it is a 350 with trickflow heads, 1.6 rockers.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: pushrod question
flat tappet cam? You need flat tappet pushrods. 7.8", give or take a bit, depending on factors.
A pushrod length checker is a good idea...
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
TFS says different
Check out TFS's recommended pushrod lengths v Rocker brand and type.
http://static.trickflow.com/global/i...od%20sheet.pdf
Car: 1982 Trans-Am
That is downright bizarre....
If it was me, i'd still buy a $14 pushrod length checker, and find out for sure.
I ended up finding that 7.875 or so was best... I found some ford cleveland pushrods that were 7.890" or so, and bought those. Heck of a lot cheaper than custom length pushrods (cheaper by $40...)
gixxer92
09-01-2015 04:32 PM
