jus installed 1.6 roller tip rockers
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
i have an 86 trans am 305 fi and i jus installed some comp cams 1.6 roller rockers i adjusted the valves and im hoping that it was the correct way i aint getting any ticking noise comin from the rockers and the car is smooth i have a jet stage 2 chip with the intake but my check engine light is on i tested it and it says that the o2 sensor is running lean any suggestions how to fix the problem thanks
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Re: jus installed 1.6 roller tip rockers
If you don't mind what do roller rockers do, and why did you install 1.6 rockers? Is there a hp/tq increase?
yea get about a 15 hp increase http://store.summitracing.com/partde...w=32&N=700+115
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
roller rockers are going to make more noise than stock rockers. comparable to a sewing machine.
1.6 rrs open the valves a tad bit more because of the increased ratio of the rockers
Car: '92 Camaro Z28
15hp on a 305? How easy are they to install? Seems worth it.
so far ive needed two weekends jus makin sure i was careful of wat i was doing they are jus under the valve covers http://www.youtube.com/watch?v=pyFIiZwmsjs thats when i got the rockers right but still have the check engine light on might need a new fuel pump with bigger psi ratio not sure anyone that can help me with that please do
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
IrocZ'85
08-17-2015 06:24 PM
