Car sometimes wont start.
I have a 1991 formula firebird and maybe once a week when I go to start it nothing happens when I turn the key. All the lights on the dash comes on but nothing happens with the engine. I let it sit for about 10 minutes and it starts up just fine. Anyone know what the problem would be?
Car: Mystifying 1989 TBI Camaro.
Engine: 1992 350 Truck Engine. TBI
Transmission: 700R4 when it wants to be.
Re: Car sometimes wont start.
When my Camaro did this, I found it to be the VATS system not working correctly. It was actually the ignition switch where the resister makes contact, it wasn't making contact all the time. I once had called a tow truck because of it, but then it started while waiting and I drove it home. Of course I canceled the tow truck so they didn't go on a wild goose chase.
I didn't want to go through the trouble and expense of getting a new ignition switch and keys, so I simply took my multimeter and measured the resistance on the key and went to Radio Shack, bought some resisters that would equal the same resistance, soldered and taped it up and it's worked ever since.
Of course the car can be stolen much easier now.
I suppose it could be rigged to a hidden switch.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
I saw a recent post concerning the Neutral Safety Switch (NSS). If the ECM is being told the car is not in PARK or NEUTRAL (I think) then the car is not permitted to start. Maybe you can 'play' with the gearshift handle when you experience the problem and see if the car successfully starts.
Is this after you've been driving for a while? If it is, then you're starter could be in the initial phases of showing heat soak. That happens when the solenoid gets too hot to turn over. If you've got headers, it's a good bet that this is what you're seeing. However, I would also check the other suggestions that you've gotten as well because it's a good idea never to rule anything out.
Too Camarorider, I was thinking about that as well but playing with the gears didn't help
theshackle
03-05-2017 06:37 PM
Linson
08-21-2015 02:12 PM
