1989 firebird formula PROBLEM!
ok well when i first bought the car it was ideling low and fluctuation and would sometimes kill at a stop. so i bought a new throttle position sensor and it worked fine for a little while. then it started acting up again. so i replaced the o2 sensor and it ran fine. now the car is having problems again. it is now ideling at 2000 rpms.. its a 305 v8
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 Trans Am GTA
Engine: 383
Re: 1989 firebird formula PROBLEM!
Sounds like it might be the idle air control. This is located underneath (and attached too) your throttle body.
Car: 96 Souped up Firebird, 89 KITT
is your vehicle throwing any codes ? if it is it could be the MAF if you have the maf version like we do, possibly the ECM, and like we found out, our engine was replaced from a 305 to a 350 and the prom /ecm goes with the engine, someone forgot to replace the ecm/prom. If you need a prom we have one for your 305 and the ecm.
theshackle
03-05-2017 06:37 PM
1989formula5.7l
08-17-2015 02:56 PM
