Where to buy A/C lines?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
My high side A/C line is leaking at the schrader valve, so I need to either replace the valve, or the line. I'm converting the car to R134, so I would rather just replace the lines anyway. I'm able to find the low side line from Autozone/O'Reilly's, but I can't find the high side line anywhere. This is the one that goes from the condenser to the evaporator, and has the test port on it. Is there anywhere other than the dealer I could find this line new?
Car: 1988 GTA
Engine: 5.0 TPI
Re: Where to buy A/C lines?
I called the dealership out of desperation, they can order the line for $60, and they also have the schrader valve in stock for $8. I was expecting outrageous prices, but those actually aren't that bad. For $8 I may try to replace the schrader valve first.
ambainb
04-25-2016 09:21 PM
db057
08-11-2015 10:11 PM
