help with distributor wiring!!
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
i will be converting my stock HEI dist to the small cap distributor. does anybody have a wiring diagram i can follow to accomplish this? would a distributor from a tbi truck work on my tpi motor? and how do you install/wire a coil? thanks
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: help with distributor wiring!!
It's more complicated than that. The small cap distributor doesn't have weights and a vacuum advance to advance the timing. It uses the ECM to control the timing. The ECM that uses a big cap HEI doesn't have the timing circuit in it. You can install the small cap one but the timing will not advance making the engine a dog.
Car: 1986 iroc
so would i have to upgrade my ecm for a later third gen model? would everything else hook up to it the same way using the stock harness? i needed to upgrade my ecm anyways since i have an 86 but swapped out the 305 for a 350 thanks for the help
Engine: 350 4BBL
You would probably have to change the entire harness.
Then there's the problem of the late model harness has a plug and your earlier engine doesn't have anything for it to plug into. It just turns into a big can of worms...
Car: 1986 iroc
what is that plug for? is there any HEI dist that will clear the HSR so i dont have to go thru all that trouble??? thanks a lot.
Engine: 350 4BBL
I don't know diddley about the HSR.
There may be some people that are using it in pre-87 cars and you can get their input on what they had to do to make it work.
