blonde color engine oil???
Car: 1984 camaro Z28
Engine: 305, 5.0 L
Transmission: 5 spd
Axle/Gears: 3.55 i think
I had my oil changed yesterday. I checked it this morning and i noticed it was a blondish color. Isn't the oil supposed to be a brownish color. I also noticed that there wasn't very much oil on the dipstick. Any help is appreciated!
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: blonde color engine oil???
Good clean oil. You're fine. Did you check it after it was running for a while? It has to sit and let the oil drain back into the pan before you can get an accurate reading. Also make sure the car is sitting level.
Engine: 305, 5.0 L
Transmission: 5 spd
It hasn't smoked that i have noticed. It's a clear gold color. i did check it after it was running and let it sit on level ground and then checked it.
edited... didn't see that you just changed it.
NOT a head gasket problem, just a fresh oil change. Oil turns brown after it gets burnt up. Fresh oil looks like honey. You're fine. I guess you're just not used to seeing clean oil.
Engine: 305, 5.0 L
Transmission: 5 spd
Well i'm not going to worry about it then. the car is running fine. I'm so used to pulling out the dipstick and the oil is brown lol.
Linson
08-21-2015 02:12 PM
Navy8125
08-21-2015 09:32 AM
