305 TPI owners... How many miles on your engine?
1 Post
Car: '88 GTA / '93 Z28
Engine: L98(350) / LT1 (350)
Transmission: 700R4 / 4L60E
I've been curious to see some of these answers for a long time and hesitated to post because I was afraid it'd get deleted or something, but anyway...
The rules for the thread are... You have to own a 305 TPI engine, you have to be on your original engine, and you should post any engine work you've have done on it before.
This is all actually going to help me decide some major things I'll explain later. Thanks for any responses I get here.
Car: 96 Souped up Firebird, 89 KITT
Re: 305 TPI owners... How many miles on your engine?
picked up my 305 tpi engine pontiac firebird formula ws6 about 6 weeks ago and it said on the odo: 199,000 but the odo is not working. Not sure if the engine was worked on or not. heck, still trying to figure out if it IS the original or someone dropped in a 350 engine in it. who knows.
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
bought it about a year ago and 86 tpi iroc z, god knows whats done to it, has alot of mods, 3 inch exhaust, auto shifter, headers, muffler, rims and tires, everything is different so i really dont know much about the engine
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
My bone stock LB9 took a crap at 117k.
Car: 1986 IROC-Z
Transmission: Automatic
Axle/Gears: 2.73?
My 1986 IROC-Z TPI 305 is probably the original. The odometer reads x14,xxx Miles, so I'm guessing 214,000 miles.
The car runs like crap, barely starts, barely stays running. I've owned it a week though and just started working on it.
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
car has just over 140,000miles bought it at 80,000 never had to touch anything internally. Replaced alternator, IAC valve. Been running a NOVI2000 (not the early ball type, this thing is a monster) for the last 5 years between 8-12lbs boost, has to be about 30,000 miles now, dont remember anymore. Current config in sig. Just barely starting to burn oil after all the torture new engine in progress
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
1985 TA 305TPI 156000 miles.
Work Done:
Headers and exhaust
Air Filter
New spark plugs and wires, didn’t need to, but figured might as well.
New MAF needed too, the old sensor died around 105,000 miles, easy change.
New rebuilt alternator, old one died, new one took 15 minutes to change and cost 80.00.
The computer is now tossing an EGR valve code once in a blue moon at sustained highway speeds so I probably should change it.
Even though I don’t need to, after this many miles I should change the fuel filter.
Other than that, it’s been a pretty reliable engine.
Oh.. one last thing, oil changes about once per year. I know and I should change it more often.
Work Done:
Headers and exhaust
Air Filter
oh so mine has 140xxx i believe, it might be 240 cuz i cant tell but the engine runs damn strong for a 305
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I bought my '86 with 57,000 on it. Re-did the top end, manifold, runners, and 56cc heads and the piston rings took a **** at 135,000
Car: 88 GTA
Engine: 305 LB9
123K on mine. Bought it six years ago with 118K and immediately ran a new intake manifold gasket, tune-up stuff, corvette fan switch & 180 degree thermo. I'm pulling it out to do the rear main, oil pan gasket and new valve seals. While I'm at it, I'm sure it will get all new belts hoses and any necessary wiring updates. The engine still runs great, but I'm tired of the little leaks and puff of smoke. I may be lining up to sell it so I want it to be all sorted out.
1 Post
OK... Mine has 113k miles on it and I was using this to get an idea of when I should start saving for a new engine. It runs very strong. Starts everytime and runs great. Thanks for the replies!
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
just pulled mine not too long ago.. 117k miles replacing with a 350 due to a lower end knock.. nothing spun just well worn bearings.. had about 17psi oil pressure at idle and a fairly loud knock.. it's rebuildable.. still havn't decided what I'm going to do with it.. its just a crappy 89 305..
Car: 1986 IROC-Z
Axle/Gears: 2.73?
1 Post
My 305 appears to be well taken care of. I had a mechanic do an analysis and he says everything is working as it should be and is in great shape for its year. I think it's just a matter of how well it was taken care of.
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
170,000 on stock 305. Last 5 years the car has only been used for a road race track day car.
car is run wide open for 20 min a time 5 times a track day. It has seen 6,500 rpms not by choice, but by wet track missed shifts, poorly excuted toe and heal technique etc.
I could not ask for a better engine.
4 alternators, 2 water pumps, 1 new distrubuter and thats all. Valve covers have never been off. Big radiator was needed for cooling and that it.
Car smokes on start up and runs very rich at idle, but no problems at WOT. I am going to keep driving it till it stops and then switch to an LSX.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Mine has 130,xxx full boltons including 125 shot of nitrous. Internally stock. Also stock transmission. replaced waterpump, and alternator. Everything else works great...so far...
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
1986 Camaro IROC Z. 305 Tuned Port. 700-R4, 3.23 axle
car has 223,583 on it and finally wont start after almost 5 years of ruthless beatings and burnouts.
Replaced Alternator, Radiator, Battery, EGR, Oil + Filter like 100 times, Installed 88 iroc serpentine setup. MAF, TPS, Coolant temp sensor, O2 Sensor, Tranny mount, transmission itself, and air temp sensor,
im about to finally pull the motor this fall and rebuild the factory 305 to better then new condition, and i can finally remove all the emissions accept for the cat.
and yes the car is staying a 305, im not looking for extreme performance, just a modest 5.0 with a mild cam and shorties
1 Post
very good. Whatever comes along I will keep mine going. I take care of my engine. I actually haven't done a burnout in about 2 months because I bought new tires and I kinda wanna keep em fresh, but if my old tires don't sell soon... YOU KNOW WHATS GONNA HAPPEN! =]
Car: 1986 Trans Am
Engine: soon to be a iron block 5.7 lsx
Transmission: 4l80e
Axle/Gears: 9 inch
I have 179,000 on mine, completely stock internals. It's had a couple bottles ran through it as well.
1 Post
Very nice! Good to see the majority of these are pretty reliable.
