runs better cold
Car: 84 Z28
Engine: LG4
runs better cold
Hello,
my car runs a lot stronger and more powerful until it's warmed up...now i know with headers i don't have a O2 sensor so I disconnected the Mixture control on the carb to stabilize, and advanced the timing. Could the car be running too lean hence after warmed up it runs worse? I'm thinking about adding a bung for the O2 sensor...any help appreciated thanks.
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: runs better cold
I would install the O2 then go here https://www.thirdgen.org/o2tuning . tHis will allow you to determine if you are rich/lean when the engine is running at normal temp using a volt meter.
db057
08-11-2015 10:11 PM
