1992 RS 305 engine swappage
Car: 1992 Camaro Z28 Convertible
Engine: 5.7TPI transplant
Transmission: a4
Axle/Gears: 3.08
I just bought a project 1992 RS camaro.
SO, I am getting a donor 305 engine with some nice heads and cam. What am I getting into in order to make this a TPI car. Obviously I need an TPI intake setup, but what other items do I need to make this a reliable day to day car?
Scott
Scott
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Basically everything that's different between TBI and TPI - the TPI induction stuff, wiring harness & sensors, fuel pump, throttle cables, various hoses, etc.
Make sure the cam is compatible with computer controls.
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: 1992 RS 305 engine swappage
TPI Swap can be a big undertaking. Your best bet is to find a wrecked donor you can buy cheap, or find one in a junkyard and pull all the parts you can from it. Go with a new fuel pump though, they're too involved to replace to use anything but new.
I swapped mine with parts from a running donor, same year as mine. A lot of work but the payoff was worth it. Flawless swap, the car started on the first try and hasn't missed a beat, except for a few issues not related.
Dave
Dave
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
