Computer Controlled Camshaft
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
Does my 1985 LG4 305 in my 85 Z28 have a computer controlled camshaft?
Thanks Guys,
Joey
Thanks Guys,
Joey
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Computer Controlled Camshaft
The computer can't really "control" a camshaft, unless you are talking about variable overhead camshafts, like in some newer cars.
Do you mean the distributor?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No thirdgen has a "computer controlled" camshaft, whatever that would be.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
In the sense that some aftermarket cams are called "computer compatible", it does.
Unless it was a Canadian delivered car.
Although, even then, it might have the same cam as US computer controlled induction engines.
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
What I think he's asking, and what I would like to know, is if we were to replace the cam, would we want to use a computer compatible cam?
Engine: 5.7 Liter
yes. Razor, you hit the nail on the head.
Engine: LS1/LQ4
The computer carb isn't extremely sensitive to the cam. The main issue is to avoid too much overlap, which can be handled fairly easily by not getting a cam with too much duration or too little lobe separation angle. Those things tend to confuse the O2 sensor.
The Comp XE series is pretty easily handled by the computer, for instance, even though they don't call them "computer compatible".
Doobie52
09-11-2015 06:19 PM
1985, 85, 87, cam, camaro, camputer, camshaft, camshafts, compatabile, compatable, compatible, computer, computercontrolled, controlled, shaft, z28
