which heads?
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
which heads?
I've got a set of 461 double humps now, and they perform great. but would a set of 58cc 416 casting heads boost my performance or hurt it? i know they will raise the compression, which generally equals power, but can they support the airflow of a 30 over 350 with a .462/.469 cam? BTW carb is a 650 holley dp.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
