stupid question
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
stupid question
can i put my 89 TPI intake manifold on pre 86 heads?
or if i cant do that can i put 89 heads on a pre 86 block
please give me some insight thx
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: stupid question
You can use just the intake by oleongating the bolt holes. If you want to use heads too they should bolt right up, and with no mods to the intake. Make sure of combustion chamber size, compression, and flow. Everything else is straight forward.
The only stupid question is the one not asked.
