timing / distributor question
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
i had a few beers last night while pulling my distributor and forgot to mark it .
can i just line up the mark on the balancer pulley with zero on the timing tab and set the rotor to the #1 spark plug wire and put it back in ? or is it more complicated than that ?
i have a 88 350 tpi .
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: timing / distributor question
As far as I know, you should be able to get #1 at TDC and then point the distributor at #1. This should be close but will require some tweaking.
Best of luck!
Best of luck!
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
the best thing i could think of you can do is to put it top dead center then line up rotor with #1
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Exactly. Doing it this way prevents you from putting the distributor on the exhaust stroke. i.e. "180 out"
Just for ease though I loosen the spark plug and listen for the hiss as the air escapes on compression build.
