Timing Chain? (Misfires)
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
My car ran perfectly one night and than in the morning it started for about 10 seconds and turned off. I replaced the distributor cap and rotar because they were in bad shape and it still sounds like it is misfiring. It won't even start unless I give it some gas and it takes forever to rev up and I have to give it a lot of gas to do so. Could it be the timing chain and if so would I have to remove the whole serpintine setup to see?
Engine: 305 T.B.I.
Re: Timing Chain? (Misfires)
From what I remember it looks like it is getting good enough fuel, I am actually going over real quick to my friends house where my car is and ill check again
Engine: 305 T.B.I.
It is definitely getting enough fuel I just tried starting it and it ran for 1-2 seconds and shut off and than next time it wouldn't turn on.
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Engine: 305 T.B.I.
No I have not. I already removed the bumper, light enclosures, etc as I need new ones anyway since they are all broken from someone who ran into me from the side and damaged it
Car: 89 Formula
Theres an easy way of checking if theres slop. Remove the dis. cap and leave the rotor on. Put a socket on the crank and turn it back and forth. If the rotor doesnt turn right away the chain is bad.
Engine: 305 T.B.I.
How do I get the lower gear off? Also how do I align the 2 gears? It looks like it skipped a whole 180. The rotor is TDC
ambainb
04-25-2016 09:21 PM
