Vortec 5700 L31 installed in a 3rd gen??
#51
1 Post
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: Vortec 5700 L31 installed in a 3rd gen??
And the TPI looks so damn cool.
Any P/Ns for a LTI cam or the ZZ4 cam that would be and improvement without head work and killing gas mileage?
#52
1 Post
Car: 91 Formula
Hydrogen has been proven to work with carbs with no problems but FI has not. So you could get the fuel economy with the Hydrogen generator and a carb.
#53
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
And with a carb, there goes anything resembling gas mileage. Something to consider with todays gas prices.
Besides, you can make more power AND get better mileage with EFI.
Yep. .490 is the max you run on a stock Vortec head. But it's fairly easy (for a machine shop) to up the lift capability.
#55
1 Post
Car: 91 Formula
I'm big fan of TPI intakes and not carbs.
This one has 906 heads.
According to Mortec the 062 were on 98.
12558062...98......350..........L31 Vortec, truck, 64cc chambers, 1.94/1.5, 170cc intake port
10239906...96-up...350.........."Vortec 5700", "L31", 64cc chamber,
170cc intake port, 1.94"/1.5" valves
What is the difference between the 062 and the 906? They look the same to me
#56
The differences are quite hazy. The concensus is that the 906 heads have a hardened exhaust seat that appears to have a 1 angle valve job done on it that hinders flow. Thus the 906 heads have a slight stigma about them. In practice, I think you should get a valve job done on used heads anyway and the problem is easily rectified.
Here's a shot of my old junk 906 heads that DANS87GTA RIPPED ME OFF with where you can see the hardened exhaust valve seat:
Sorry, Im still angry at the punk for ripping me off on them...
#57
1 Post
Car: 91 Formula
062 didn't have hardened exhaust seat but a 3 angle valve job?
How did that happen to your heads?
#58
Car: 87 GTA
LT1s still use a dizzy-type shaft as an oil pump drive...Right? So I think a LT1 cam would swap right in, no problem. At least, I've never heard of anyone having to get a gear pressed onto the LT1 cams. Just the issue of the nose pin being different, for the Opticrap, which is easily swapped out for the right pin.
#59
1 Post
Car: 91 Formula
I'm just going to stick with the L31 cam or the 90-92 L98 cam.
#60
But either way, it's a bit OT so I'll let your thead continue.
#61
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Ok, I just checked Autozone and Advance and they are stating the same thing as Summit did. 88-92 Camaros and Firebirds use a reverse rotation WP and 96-2000 Vortec V8 use a standard rotation WP.
Is this because of the different Acc.-Serp setups on 88-92 Camaros and Firebirds compared to a 96-2000 truck setups?
The "reverse-rotation" is because of the serpentine belt system. Think about it for a second. Which pulleys on a serpentine system drive off the backside of the belt? The water pump, the tensioner pulley, and idler pulleys, are the ones driving on the backside of the belt on most serps. The easy way to remember it, is the belt wraps around the pulley in the opposite direction to drive of the back. Thus the pulley spins in the opposite direction.
It is not easily possible to mix them up. The pulley mount holes are drilled/tapped differently. Don't ask how I know that. It's one of those things one is embarassed to have done.
#62
1 Post
Car: 91 Formula
I finally got it earlier, it was Advance, Autozone and Summit that confused me because of their descriptions of the WPs.
#63
L31 cam specs are not THAT far off the 92 TPI specs, but theheads themselves flow WAY better...plus the seqential firing order of the inectors equals better mpg. If you use the L31 ECM, distributor & wiring.
96 L31 Camshaft Profile
Intake: .275 X 1.5 = .412
Exhaust: .281 X 1.5 = .423
Lobe Separation 111 Degrees
#65
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
SUBSCRIBED! Thanks, been looking for a thread like this. My Camaro needs a valve job. And I have a Vortec 5.7 out of a 99 Express laying around that I wanna convert to TPI and drop it right in.
#66
1 Post
Car: 91 Formula
I have heard the the Vortec heads are prone to cracking, if so where are the cracking at?
I believe I read some where on a aftermarket Vortec head manufactures website that the beefed up the area where the GM Vortec heads were cracking.
#68
Car: 88 GTA "Cocaine"
Engine: 350 tpi
tally what you spend and I will smoke you with a first gen block
170cc 64combustion cambers
why are these heads worth a ton
I would get some run of the mill 081 a carbide bit and some paper rolls and kill those heads
#69
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yeah you spend your time porting the **** out of those 081 heads and he can bolt up his vortecs and put down the same if not more without touching the heads... and if he decideds to clean them up a bit even better... there is a reason they say the vortec head is the best gen1 production head ever...
oh yeah try and find a difference in a "vortec block" and a gen I block
#70
1 Post
Car: 91 Formula
I just got a recommendation to use a stock LT4 cam(not the LT4 HOT cam) in this L31. I know about the Memcal being programmed.
What would I gain from the stock LT4 cam compared to the 90-92 stock L98 cam or the cam in the L31?
FYI, I'm sticking with the 90-92 SD TPI setup with the Vortec TPI base.
Specs on the stock LT4 cam
INTAKE: DURATION/LIFT
@0.05 191 .418
EXHAUST: DURATION/LIFT
@0.05 196 .430
LOBE SEPARATION 111
90-92 stock TPI cam:
10111773 202/207 .413/.428 .441/.457 114.5 90-92 350,305
@0.05 191 .418
@0.05 196 .430
LOBE SEPARATION 111
#71
Car: 1983 G20 Chevy
Transmission: 4L60
@0.05 191 .418
@0.05 196 .430
LOBE SEPARATION 111
@0.05 191 .418
@0.05 196 .430
LOBE SEPARATION 111
The LT4 cam is an awesome cam upgrade for the L31 Vortec engine. It has more lift, more duration, and a wider LSA. It has more area under the curve as well. It is a very smooth idling camshaft that likes to rev. The LT4 cam fits in with vortec heads very nicely, with LT4 .050" offset retainers, shims, and a good set of valve springs. I have one in my otherwise stock L31 Vortec longblock in my Fullsize G1500 Conversion van. With the 2,000 rpm converter and Tri-Y headers, it came to life all over the powerband. It pulls hard from just off-idle all the way to the 5,600 rpm fuel shut-off on the stock tune.
#72
1 Post
Car: 91 Formula
What difference would you see?
Again, I'm weak on cams and the L31 stock cam will not be used.
#73
Hey everyone. Just registered. Glad to find people that know a little bit about the Votec 350/5700/L31... Whatever you want to call it. I have a 96 L31 in my 77 Camaro.
I'm glad to find out that the cam is a roller cam, that makes it a lot easier to swap it out without having to get a "retro-fit" roller cam.
So I keep hearing that the Vortec heads are awesome and they'll sell really well any everything. I understand that they outflow other OE heads and everything, but why should I keep them over buying a new set of something like Edelbrock E-Tec 170cc heads? Obviously with the E-Tec 200cc heads there's a bigger intake runner which makes it clear why that head would outperform the stock head. But would the 170cc E-Tecs actually outperform the stock heads with the stock cam?
And just how much will the OE Vortec heads go for?
Also, how many horses will the rotating assembly take before having to change that out? It's probably a cast crank and pistons?
Lastly, I read that the max lift on the stock head was like .490. That's just because of the valve stem length right? How far till you reach the piston?
I guess what I don't get is, if I put an E-Tec head on my L31 and the max valve lift is .575 and the cumbustion chambers are still 64cc, There must still be room with the stock head to change out the vavles and springs for a higher lift then, right?
#74
Setting cost aside and going aftermarket heads, the usually cant compare without significant porting, and even then a ported aftermarket usually trumps them again
Further reading
http://www.customclassictrucks.com/t...evy/index.html
#75
Car: 87 GTA
There is now a conical spring set available to replace the stock ones. Which like any other spring set.....You can replace the Vortec ones at home, with no more than pulling the rockers off.
Upping the calve lift ability over stock. Simple upgrade.
Or you can buy brand new Vortec heads that already have the spring replacement done for you.
#76
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
just leave the vortec cam in there, it is almost identical, and not really worth the effort to take it apart, the vortec cam is a little better aswell. it will run just fine on the stock prom
1992rs/ss
05-19-2020 07:02 PM
84z96L31vortec
08-20-2017 12:16 AM
Fast355
12-02-2016 06:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
84z96L31vortec
08-10-2015 08:27 PM
