'97 Firebird failing to turn on at times.
This is a recent issue i've had with my Firebird. Now what happens is when I get in the car, and put the key in, the power will turn on and every as usual, but then when I turn the key, the car just dies. The engine doesnt start and when I keep turning the key, it just stays dead.
Now I found out that if I get out and open the hood, and shake the battery a little, it'll restart and I can go back in and try to start it up again. Sometimes it'll die again, and other times it'll start up and run just fine.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: '97 Firebird failing to turn on at times.
Loose battery cable?
That would be my first suspect, because it is the easiest to check.
