Starter engaging on flexplate
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
I'm trying to install my flexplate on my new engine, and the starter is engaging on the flexplate. I thought I had a bent flexplate, so I bought another one and have the same problem. If I rotate it, I can get it to not hit at one point, but theres still not a lot of clearance. So now I'm left with either faulty starter, or where the flexplate bolts to the crank isn't true (I hope not). Is there something I'm missing? First pic is the most clearance I can get by rotating it, second is it hiting
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Starter engaging on flexplate
spent some time and read this and looked at the picture
not the smartest guy on the planet so I have to say I have no idea what you are talking about
just take your time and spell it out for us dummies
wait i can only talk for myself
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
Just to double check a few things.
You have a 383. So basically you have a crank out of a 400 CI motor in a 350 block.
Are you using an externally balanced Flexplate for a 400?
Car: 85' Z28
Engine: 383 roller
Yea its a 383, but i used an aftermarket internally balanced crank from scat. I tried a brand new flexplate from scat as well as tci and have the same problem. I'm stumped, something is obviously bent or wrong because it makes no sense that at one point theres some clearance, and then at another it hits. I"m trying to track down another new starter so I can try that.
Gunner242
12-25-2015 04:49 PM
