camaro is running again! have a question though.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
the camaro is running again after i did the serpentine swap (march pulleys), weiand high flow team G mechanical water pump, flexalite fan (eliminated clutch), new alternator and a few other things...
here is the question though. it seems like it takes alot of time to get the fuel up to the carb (mechanical fuel pump), i am doing alot of cranking and alot of pumping of the gas pedal to get the fuel up there...
does anybody know of something that i can do?
note: the carb is still untuned, i dont know if that is playing a role. i am going to be working on that in the next couple of days. then i all of the HEI ignition is going on. i will post some pics up later.
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
