Serpentine Smog Pictures
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Hey everyone,
I'm to the point now where I have to decide if I want to put my serpentine set up on or not...the only question I have is on the smog stuff. Does anyone have any "good" pictures of how their smog gear is installed so I could see it with my own eyes? On my 84 T/A, my diverter valve (the things that sit on the passenger side, divert air to the cat etc) have both electrical connections AND vacuum lines going to them. The new ones I recieved have only the electrical connections, and to top it off the connectors are a different type. If you guys have any info on these I would greatly appreciate it because if I can't get the smog stuff running, I can't use the serpentine. And I really want to. Thanks again!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Serpentine Smog Pictures
I can tell you how it looks on my '91 serpentine setup. There is a metal tube under the diverter valve that goes to the air pump. One rubber line from the diverter valve goes to a plastic T, that goes to the passenger side AIR tubes to the manifolds, and to another rubber line that goes around the back of the engine to the driver's side manifold. The other rubber line on the diverter valve goes to a metal line that goes down the back of the engine to the catalytic converter. Sorry I couldnt find my pics.
Car: 1984 Trans Am
Hotrodboba400
12-10-2019 07:07 PM
tonys91rs
10-10-2015 03:31 PM
