deleteing emissions and advice?
Car: 1986 trans am
Engine: 305 with almost 2000000 on it!!
Transmission: 700 r4
hey guys, i am on the westren slope and i have an 86 t/a that i am wanting to take the emissions crap out of and clear up some room in the engine compartment. i am leaving most of the other stuff in, it isn't going to be an extreme build but that emissions is just in the way. does anyone kow if it's gonna start throwing codes and running like crap because i yanked the suff? new to building but am looking to learn as much as i can
AB70 (07-22-2023)
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: deleteing emissions and advice?
hi there there really isnt much need to remove the smog pump or really anything else unless there isa fault with it and it is non operational or causing a problem with the engine
the smog pump doesnt affect horsepower at all and actually helps things because it simply injects fresh cold air into the exhaust and makes any unburnt fuel in the exhaust burn completely
there really is no other emissions equipment other than the Q jet carb that has an electronic fuel mixture solenoid in it and other than that you have your EGR valve but that does not affect performance either and actually can help keep the engine runnig cooler anyways
a/c and other things are what takes up alot of the room under the hood
i personalyl never remove emissions equipment especially the AIr pump system unless it is broken or not working already
if the engine is running fine then i would leave well enough alone and save yourself headache and money and leave it alone
good luck
good luck
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Are you building a show car or strip car?
If not, leave it on. Your grandkids will thank you.
Car: 1986 trans am
it isn't a show car but isn't a strip car, just gonna drop a new engine in it eventually and i don't want all tat stuff that colorado doesn't require taking up space in there
AB70 (07-22-2023)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
But it is required, by the Federal government, and the state government, even if your area doesnt test for it. Please this board and the exhaust board, there are several heated threads about removing emissions equipment already.
Car: 1986 trans am
great i'll check, i wsn't sure where to post it at, i am not looking to polute the earth and kill all the tree hugers, but i want to clean up my engine compartment, and if i get nice vavle covers and dress up the engine no body will be able to see it, but i will look around here more to see what people think
86White_T/A305
09-21-2015 05:28 PM
