Camaro way faster than I thought !!
My 1990 Camaro 5 speed seems to turn 8,000 RPM easily.
I don't believe it either so I changed out the tach and electronic card mounted with the tach.
It still reads high...idles at 1100- 1500, shows 5000 Rpm at 3000.
Any ideas of what I should try?
thanks Al
![bs](https://www.thirdgen.org/forums/images/smilies/bs.gif)
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
thanks Al
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
Re: Camaro way faster than I thought !!
try a handheld tach to see what your rpm's really are. you could put an aftermarket tach in.
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
mine did the same thing so i just bought an autometer tach reads perfect looks funny tho both tachs that dont match each other on rpms
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
And here i was thinking somthing was off in my car because it ALSO idled around 1100 RPM
This must be a pretty common problem! It seems like there are quite a few people who have this issue.
p.s. my car is a 89 Iroc 5-speed
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Axle/Gears: '01 3.42 10 bolt
there is a tech article somewhere on thirdgen.org explaining how to fix you factory tachs so they are at least close. i think it is in the tech articles accessed from the home page.
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
yeah when I bought my 91 RS the tach was way off, read 3000rpm at idle
I did the fix on the tech article, only I used a potentiometer to adjust the tach to match what my laptop said the RPM was (via ALDL cable)
got it perfect, matches the ECM readings spot on (gets slightly off at high revs, but only by like 100rpm)
CarGuyDennis
137
12-06-2016 11:02 PM
