carb
Car: 85 z-28 and 96 z-28
Engine: 383 storker and a 350LT1
Transmission: 700R4 and 4L60E
Axle/Gears: 3.23 and 3.73
carb
i replaced my carb on my car with one i got from a friend. it has electonic choke and the car had a tpi unit on it so how do i run the electronic choke for the car and also the car runs like crap when the choke is open and runs good when the choke is closed is that meaning the car is getting to much fuel when the choke is open
Car: 82 Z-28
Engine: 383 TPI
Re: carb
Elec choke should be connected to a circuit that is powered only when the key is in the "run" position.
If a warm eng runs better with choke closed, it's running too lean. There's a good chance there's a vacuum leak.
Car: 1986 Chevy Silverado
Engine: 350 Crate
Transmission: Turbo 400 w/ shift kit
Axle/Gears: dana60/corp14 4.10 gears
Re: carb
I had an electric choke on my old carb and I ran it off my distributor.
Trey
Dude thats my car!!! My engine looks the EXACT same.
Trey
Last edited by DCOWBOYS1975; 06-04-2008 at 10:47 AM. Reason: Automerged Doublepost
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
