e-85 gasoline
e-85 gasoline
i think ive heard of e-85 carbs and such but can you buy one of those to use on a engine with high compression like a motor that you would need to run premuim in or higher? since e-85 is i think 105 octane
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
E85 is typically in the 105 octane range. The carb won't be affected by CR so much, so yes, you can use an E85 carb on an engine built for E85 octane.
Engine: LS1/LQ4
Depends upon how deep into it you want to get.
The QFT E85 750 CFM DP uses the Proform mainbody, their alcohol billet throttle body, stainless steel needle/seat (.140", I think), larger jets, and their E85-specific billet metering blocks.
The key is the metering blocks - the idle and power valve restrictors are enlarged, and the emulsion bleed orfi are modified.
You have E85 available in central Florida?
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: e-85 gasoline
The difference is you have to run more alcohol per air unit, so just about every hole in the carb needs to be bigger to run correctly.
CSU and AED make e85 carbs that I know of, maybe edelbrock. Theres also quickfuel metering blocks that you can stick in your holley, but I don't know how well they work. (cheap)
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: e-85 gasoline
Not to mention too that alcohol safe rubber and gaskets must be used. Ethanol will eat rubber.
Engine: LS1/LQ4
Not true. Methanol may eat "normal" soft parts, but fuel components have been ethanol compatible for a couple of decades now.
Re: e-85 gasoline
alright so say if my 350 with flat top with 4 valve reliefs with stock 601 heads off a 305 i think there 53 or 52cc has to high compression to run on pump gas can i get a e85 carb and use that since the octane will be higher in that fuel?
Car: 91 rs
Axle/Gears: 3.50 9"
Re: e-85 gasoline
IIRC, guys have run up to 16:1 with E85 and no detonation.
Five7-so you like the QFT blocks? How much tuning did you have to do to get it close? I'm thinking about changing my BG mighty demon blow through over.
Engine: LS1/LQ4
12.5:1 CR is what I've heard without extreme measures. A 350 with 5cc reliefs, 601 heads, and .040" quench should be fine with E85.
My history: The metering blocks were the last thing I got. I already had the Proform main body running gasoline with standard Holley for the rest. I first tried upping the jets and reducing the air bleeds - worked okay WOT and cruise, idle was terrible. I next tried Proform billet metering blocks, but never got the proper idle feed, power valve restrictors, or emulsion bleed restictors. I installed a QFT alcohol base plate since the Holley was poorly machined, that helped idle a little. The QFT E85 blocks made a difference in power that I wasn't expecting, as well as finally getting a decent idle. I put the air bleeds back to stock Proform (for 4-corner idle) when I put the E85 blocks in. Jetting per QFT recommendations.
I don't recall off the top of my head what BG has available for E85.
Car: 91 rs
Axle/Gears: 3.50 9"
Re: e-85 gasoline
Sounds fairly painless, I just wonder since its a carb set up for blow through, if the blocks are different...
Race gas is getting pricey.
Justin92GTA
08-27-2015 11:16 PM
