Lifters Question
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Lifters Question
I just got off the phone with a SummitRacing tech and he told me that I cant resuse my lifters when i change cams, Is this true?
My motor is a '87 TPI 350
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You can reuse roller lifters.
If you were talking to him about a flat-tappet cam, you can't use your roller lifters on that type of cam.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Lifters Question
Roller lifters CAN be reused if they seem to be in good shape (no gouges on the wheel or lifter machined surfaces, wheel spins smoothly and is not loose, etc)
Flat tappet lifters should NEVER be reused when changing the camshaft.
Mickeyruder
09-02-2015 02:45 PM
