cutting out at 5500rpm
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
Axle/Gears: 10bolt 3.42/posi
Car has just started doing this. plugs are new, wires are new, dist. cap looks ok, coil is new. Only thing that someone has mentioned is the ignition box.
Plugs, AR133s
Wires, MSD 8mm
Coil, MSD Blaster SS
Ignition box, Crane Hi 6
Setup,
383 10:5:1
Iron Heads
Stealth Ram with 950ecm
it doesnt feel like its blowing the spark out. It acts like its hitting a rev limiter at 5500. It did it then i replaced the plugs, and played with the timing with the dist a bit and i thought it went away then the other night it was doing it again. Any thoughts would help me in figuring out why the car is doing this. Ran fine all of last year.
Plugs, AR133s
Wires, MSD 8mm
Setup,
383 10:5:1
Iron Heads
Re: cutting out at 5500rpm
Plugs, AR133s
Wires, MSD 8mm
Setup,
383 10:5:1
Iron Heads
Plugs, AR133s
Wires, MSD 8mm
Setup,
383 10:5:1
Iron Heads
Have you checked to see if your plug wires are grounding out on your headers?
Car: 90 RS Camaro
Engine: 383L98
Transmission: t-56
thanks, ill try playing with the timing some more. im pretty sure the wires are not grounding out on the heads, i had an experienced builder put my motor together. i can easily rule out the box if i bypass it, but ill try the timing thing first and see what happens.
