96 impala ss lt1 cam specs?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm looking for a used lt1 cam and I came across a fairly cheap one from a 96 impala ss lt1, what are the specs? Are they the same as the vette/maro cams or no?
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 96 impala ss lt1 cam specs?
i thought i heard the F-body cam was different but cant remember
The cams are significantly different:
B-Body LT1: INT - 191º .418" EXH - 196º .430" LSA - 111º GM P/N 10243779
F&Y -Body LT1: INT - 203º .477" EXH - 210º .480" LSA - 117º GM P/N 12551705
Y-Body LT4: INT - 203º .476" EXH - 210º .480" LSA - 115º GM P/N 12551142
Y-Body "Hot" Cam - INT - 218º .525" EXH - 228º .525 LSA - 112º GM P/N 24502586
Basically, the B car cam is a reasonably good choice for a 305 TPI. The standard F/Y car cams are a decent factory grind for a 350. The LT4 "Hot" cam would require head work, but in a standard installation with 1.5:1 rockers, the specifications are much closer to the stock LT1 cam. (The LT4 used 1.6:1 aluminum rockers to yield the specs above.)
thanks for the info! I guess thats not what I'm lookin for..
gixxer92
09-01-2015 04:32 PM
