stumble
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
stumble
I don't know if this is a carb or ignition problem but sometimes my car stumbles a little when your light on the throttle?
and won't stay at a steady idle it'll bounce between 700 and 900 RPM?
my car is a 82 trans am with a 305 T-10 4-speed.
I have a Edelbrock 1406 carb, and a MSD HEI distributor.
Any help would be great.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: stumble
its running lean.. get a calibration kit and up the primary jets one at a time until the problem stops..
not sure on the idle though..
Car: 1982 Trans am
Engine: 383
Re: stumble
Car: 1984 Trans Am
Re: stumble
well that i dont know.. my car used to stumble at part throttle then i upped the jetting and its smooth.. maybe the springs are too stiff?? and not letting the needles open fast enough..
then again, smoke usually means rich or oil.. does the motor burn oil??
Car: 1982 Trans am
Engine: 383
Re: stumble
Would a fuel pressure regulator help? I have a Holley 80gph 7.5 psi fuel pump. I thought carbs only need like 4-5 psi
RedLeader289
05-28-2019 01:47 PM
