Need help setting the timing
Car: Red T-Top 89 IROCZ
Engine: 400 / punched out 30
Transmission: 700R4 / 3500 stall
Axle/Gears: Ford 9" 390 gears
I just put a 406 with a small cam in my 89 IROCZ, was needing some help as to what is the bust setting for the timing. Can you help
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Need help setting the timing
It depends on the cam specs, the compresion ratio and the intake system. Need more info. We can give you a starting point but it will wind up being what the engine "likes". This is part of the tuning process.
